  3. NETLIST_IGNORE in Capture
  • Views 11089
JuriV
JuriV over 4 years ago
I have severel schematics in the project. One of Schematic I want use as documentation sheet. E.g. I placed a small circuit on this sheet with the same Ref Des like in the real circuit.
Is it possible to define the compoanets on this docu sheet "as not in the netlist" ? I have tried to set the "NETLIST_IGNORE = TRUE" and "BOM_IGNORE=TRUE" but doesn't any success.
  • excellon1
    excellon1 over 4 years ago
    So the idea of the Schematic is to generate an electrical netlist from wires & pins on symbols. To get around what you want to to do with respect to the documentation try the following.
    On the sheet that you wish to capture press the print screen key on your keyboard to "Capture" the screen. Next using a suitable picture viewer such as paint or something similar select paste
    to paste the contents captured from your print screen operation. Lastly crop the picture and save it to a file.
    On the schematic sheet that you are using for your documentation just insert the picture using "Place Picture" from the tool bar.
    All the best.
