  3. Database TCL commands, referencing an object
  • Subscribers 163
  • Views 14193
jelman
jelman over 5 years ago
I am creating a TCL script to create a large pin count part.  After reading through the OrCAD Capture Tcl/Tk Extensions – Application Notes, I'm still a bit confused about how to load in a library object.  Can I do this by file path, or by name inside a session?  Is $Name in get lib a file path?  Also, what is the difference between GetLib, GetLiband Schematics, and GetOpenLib?  There aren't descriptions for these functions, just I/O datatypes.  Is there some other references I should be looking at other than OrCAD_Capture_TclTk_Extensions.pdf?
  • jelman
    Seems like I got this first part working.  I can open a library object and check the name:
    #create session object for this session
    set lSession $::DboSession_s_pDboSession
    DboSession -this $lSession
    #create state and name variables to pass to functions
    set lStatus [DboState]
    set lName [DboTclHelper_sMakeCString]
    #filepath to TCL string to C-string
    set pLibPath [file normalize {C:\Library\CONNECTORS.OLB}]
    set lLibPath [DboTclHelper_sMakeCString $pLibPath]
    #open library object from filepath c-string
    set lLib [$lSession GetLibAndSchematics $lLibPath $lStatus]
    #check name of library object
    $lLib GetName $lName
    puts [DboTclHelper_sGetConstCharPtr $lName]
    but, I can't seem to load a part out of the library, 1551920-2 is the name of a part in the library.  I just get a NULL for the object when I run this code.  Any idea what I'm doing wrong?
    set pPart_Name {1551920-2}
    set lPart_Name [DboTclHelper_sMakeCString $pPart_Name]
    set lPart [$lLib GetPart $lPart_Name $lStatus]
    puts $lPart
