  3. DRC report window disappeared
  • Views 12203
Firas Abdel Ghani
Firas Abdel Ghani over 4 years ago
I'm using Orcad Capture 16.5.
for some reason, while running DRC, I stopped seeing the report in the bottom of the screen, and instead, I have to go to the *.DRC* output file in some directory.
how do I make the window that used to show the report quickly appear again?
  • redwire
    redwire over 4 years ago
    Make sure that "Window->Session Log" is checked.  Another thing to check box is "View Output" when you run DRC and it will pop up a separate window with the DRCs for you.
