  3. Signal Model
  • Views 12160
Signal Model
atoddrich
atoddrich over 5 years ago
When trying to change the default transmission lines to reflect my design they will not stay.
By that I mean when I save and open the signal model again it has the old (default) models still there. I cannot change the parameters either.
I am doing this in SigXplorer from Allegro constraint manager.
  • AvengerThanos
    AvengerThanos over 5 years ago
    Delete the existing Tline model on canvas and place it again, and see if you can edit the TLine parameters or not. On the right side, you would see the window where you can edit parameters.
    In your case, any warning generated in the command window?
