  3. Simple Highlight Problem...
  • Views 13038
archive over 19 years ago
When I highlight nets in allegro 15.5 just a corner of the pins when I click on them. It's just an annoyance to have search for a segment of colored circles to find the nets I need. Is there a way to have the highlight function fill the circle on the pin?
Originally posted in cdnusers.org by jskaanla
    Try setting the following env variable and restart the editor
    edit ~user/pcbenv/env # file
    set DISPLAY_NOHILITEFONT
    --nanda
    Originally posted in cdnusers.org by nanda
    In addition to setting the DISPLAY_NOHILITEFONT, you may want to experiment with turning on and off the, "filled pads" and "Cline endcaps" Display options. They are found under the Setup pull-down menu; Setup => Drawing Options (Display tab)
    Randy
    Originally posted in cdnusers.org by rb
