  3. Pushing occurrence properties to instance
  • Views 10820
Shafeeqt
Shafeeqt over 4 years ago
In my design, all the properties are updated in occurrence (the properties in the instance is different , the design is flat design). I wanted to copy all the occurrence properties to instance properties. But when I try to push the occurrence to instance, all the instance properties are getting copied to occurrence. (used option Accessories> Transfer Occ. prop, to instances > Push Occ. prop, to instances)
Can anyone help to solve this issue?
I have tried in Orcad capture 16.6 version and Orcad PCB editor 17.2 version also
