  3. problem with removing layers on the cross section edito...
  • Views 11436
problem with removing layers on the cross section editor
masamasa
masamasa over 4 years ago
hello
i have removed all symbols, clines, shapes, vias and everything from the design file but still can not remove the layers on the cross section editor.
i have remove symbols from the parts list and purged all padstacks and nets as well.
i have also removed all the setup on the artwork control form.
what else do i need to purge from the design file in order to remove layers on the cross section editor?
  • steve
    steve over 4 years ago
    You usually get a log file that lists the objects and locations. If you are not seeing that try a Database Check and see if that helps.
