  3. How to measure distance between pin center and board outline...
  • Subscribers 166
  • Views 9937
How to measure distance between pin center and board outline?
PCBWiz
PCBWiz over 4 years ago
             I need to measure the exact distances between a pin center and board outline along X axis and Y axis. How can I do that?
Thanks.
  • steve
    steve over 4 years ago
    So try the Check - Measure (or Display Measure) command. Check the Find Pane to make sure the items you want are enabled then select the pin then the board edge. If you are happy with the selections (or need to be more accurate) hiver over the item and right click - Snap Pick to - Object type (pin, segment vertex etc).
