  3. Importing a text file
  • Subscribers 163
  • Views 16033
archive over 19 years ago
Is there a way to import a text file into PCB editor?  We have fabrication notes in a word document or notepad that we would like to import without having to type them in.
thanks
Originally posted in cdnusers.org by paulm
    Add text(check filter to make sure you are on the layer and text size you want)place text right click add text from file
    Karen
    Originally posted in cdnusers.org by kbarker
    Yes.  If you are in the Add Text command, you can RMB and select "Read  from File".
    Hope this helps.
    Originally posted in cdnusers.org by cdavies
    Also,
    If you want to import text from Excel, I find that if you first do a "Save as type: Formatted Text (Space delimited) " from within Excel, it works very well.
    Randy
    Originally posted in cdnusers.org by rb
    Thanks to all who replied, all suggestions worked fine.
