  3. Problem deleting layers in stackup
  • Views 13748
cstocci
cstocci over 4 years ago
Got a 8 layer stackup PCB design in Allegro 17.2 and want to remove a few layers as they are no longer necsaary and this would reduce the cost of the PCB too.  However, when I try to remove a layer in the stackup manager (I have version 17.40.019), I get the following error:
"ERROR(SPCMGR-368): Could not delete layer "GND4" from application database."
Any suggestions?
Chris
  • steve
    steve over 4 years ago
    There is usually a report shown that lists why the layer cannot be removed, look at that and make sure all objects on that layer are deleted. if that still fails try a Database Check on the board which may fix the issue.
