  3. RE: OrCAD Allegro 17.4 - How to adjust the position/location...
  • Subscribers 166
  • Views 1706
RE: OrCAD Allegro 17.4 - How to adjust the position/location of header and footer text in exported PDF
VKPA
VKPA over 4 years ago
Hi
I am exporting allegro artwork PDF in ANSI C size, The Board size small like 1.5" X 3 ".
Is there any settings, so I can get the header and footer text next to board outline on top, bottom or either side of the board.
1. PDF exported with current settings
2.  Solution looking  for something like this
  • AvengerThanos
    AvengerThanos over 4 years ago
    In the Export - PDF option goto page setup under scaling you can scale the PCB size or select fit to page. The output would be as expected.
