  3. A bus of netgroups
  • Views 11776
A bus of netgroups
stevensen1
stevensen1 over 4 years ago
Is it possible to make a bus out of several netgroups in Capture?
I have created different netgroups named CH0, CH1, CH2 .. CH19.
Can I connect them together as a bus named "CH[0..19]?
When I tried this solution I get the DRC error "net has less than two connections" for the nets that are defined inside the respective netgroups.
  • AvengerThanos
    AvengerThanos over 4 years ago
    The error meant that another end of the bus is left unconnected. Connect the other end to resolve the issue.
