  3. OrCAD Capture TCL script to set variant view.
  • Subscribers 163
  • Views 11444
alager
alager over 4 years ago
I am using OrCAD Capture CIS 17.4.
I have not found a way to variant steer the Titleblock properties (except <Variant Name>) so I am working on a tcl script that can do this for me.
My approach is to change the value fields of the titleblock properties with respect to the active variant.
I have found the functions called "GetActiveVariant" and "SetActiveVariant" but I do not understand how they're working. I have tried to use them to change the variant view of my schematics with no success.
If I read the CLI with the "show journaling" setting on, I can get a command that changes my variant view. The problem is that the command is using a path to an .xml file which seems to be stored in a Temp folder on my local user and I need the script to work for an arbitrary user.
Does anyone have any experience of something similar?
Best regards,
Alexander
