  3. easy way to replace via in board file
  • Replies 9
  • Subscribers 163
  • Views 21079
archive over 19 years ago
Any easy way to replace a via in a design without the use of skill.
Mihai
Originally posted in cdnusers.org by mihaii
    Tools->Padstack->Replace, then put in the old and new padstack names.  Can do for the entire board or just a single via.  You can also record these steps in a script and assign it a keyboard shortcut.
    G'Day,
    R²
    Originally posted in cdnusers.org by Randy R.
    I tried the first suggestion and it worked.
    I have created a .scr per your suggestion, but when I run it the script replaces all the vias with the desired padstack.
    On the script be sure to check "Macro record mode".
    When recording the script: after inputing the padstack names and before clicking on "Replace", check the box "Single via replace mode".
    when I try to do that the Single via replace mode is grayed out.
    That's different from the version of 15.5 I'm running.  As soon as I enter the "Old" padstack name, that box isn't greyed out any more.  That's why I said to select that box after entering your padstack names.
