  3. Database Check Error - Ratsnest lines are out of date
  • Views 1033
ameehan2
ameehan2 over 4 years ago
Brd was moved from 17.2 to 17.4, new constraints imported, and artwork won't run due to this error repeated 67 times:
ERROR: in NET net name = DDR_BL2_DM
  WARNING(SPMHDB-43): Ratsnest lines are out of date.
   Error was fixed.
I can only run artwork if I uncheck the "Check database before artwork" box
ODB++ runs fine as well.
If it says the error was fixed, why isn't it fixed? Every time I run dbdoctor, I get the same 67 errors.
Any feedback would be greatly appreciated.
Thank you.
