  3. Make a BOM export include the netname field for each component...
  • Views 10693
Make a BOM export include the netname field for each component?
WAB1
WAB1 over 4 years ago
We have dedicated test point components that are a single pin component and I'd like to generate a BOM output that lists all of the Test Point components along with the netname value.
I get the BOM export to show the test points easily enough, but cant figure out how to make the net name be included in the export.  When I look at each test point property I can see that the netname field / value exists, but cant see how to get it on the BOM as netname doesn't seem to be a vaild field type.
  • RFinley
    RFinley over 4 years ago
    The easy solution is to open the board in Orcad/Allegro then generate a "Component Pin Report".
    You can select the data with formatting and paste it into MS Excel.
    Excel breaks it up into rows/columns.  Easy to delete data you don't need.
    This could be a good SKILL application.   But, SKILL documentation for accessing netlist information is unfortunately, nonexistent.
    If a SKILL 'find' function works, there is a script I shared over on the SKILL group that shows how I process netlist info from DRC errors.
