  3. decompose a component
  • Subscribers 166
  • Views 13444
myil17
myil17 over 4 years ago
Hi everyone,
Can anybody tell me how to decompose of existing custom made component?
I need to enlarge one of the pin hole of a mosfet. Is there an easy way to do it?
Best regards
  • Eric Jordan
    Eric Jordan over 4 years ago
    If you have the source footprint and pad stack files, you can modify the pad stack and update the footprint (Tools->padstack->refresh).
    If you dont, you can edit the footprint from the board design. It's in the menu somewhere, not at my computer.
    You can also export all the footprints on your board and make changes to the footprint as well.
  • myil17
    myil17 over 4 years ago in reply to Eric Jordan
    How can I export all the footprints?
  • steve
    steve over 4 years ago in reply to myil17
    File - Export - Libraries (or Export - More - Libraries in OrCAD) pick a folder location and export. This writes out any filename.dra, psm, bsm, ssm, osm, fsm and pad files to the chosen directory.
  • myil17
    myil17 over 4 years ago in reply to steve
    Thank you Thumbsup
