  3. Cannot create sub drawings
  • Subscribers 162
  • Views 14942
archive over 20 years ago
Just upgrade to 15.5 and sub-drawing is not working. After creating the sub-drawing and picking the "Pick clipboard origin point" an error message comes back.
E- *Error* eval: undefined function - axlSnapToObject
No sub-drawing is created.
Here are some other error message on opening a design.
E- *Error* alias: alias is already used as function name - _axlDBCreateSymDefSkeleton
E- *Error* alias: alias is already used as function name - _axlDBCreateComponent
E- *Error* eval: undefined function - axlReportRegister
thanks
Originally posted in cdnusers.org by Jeff
    Just some ideas:
    You are just upgrade t 1.5:
    First, do you somewhere in your configuration some files from olders version?
    I mean:
    - Have you customise CDS_SITE
    - Have you TELENV variable?
    - Do you have old files in you $HOME/pcbenv?
    Secund, do you have install ISR's?
    Originally posted in cdnusers.org by jcteyssier
    Can anyone be more specific on this matter, I get the same Error since I loaded 15.5.1 and I have the latest ISR loaded.
    Originally posted in cdnusers.org by pkeefie
    Check your paths in your OS Environment Variables. I am pretty sure that I have seen this before when some of the system variables were still pointed at old software tree locations.
    Originally posted in cdnusers.org by kp
