  3. Pin Name
  • Subscribers 163
  • Views 14995
Pin Name
archive over 19 years ago
Is there a way to assign pin names to pins in Allegro or APD?
Originally posted in cdnusers.org by JB71
    Hi JB71,
    What's the meaning of "pin names"? pin numbers? If yes, I think it is impossible.
    Tom
    Originally posted in cdnusers.org by ding
    Hi JB71,
    If you mean that you want to use other characters than figures to define a pin, then the answer is yes. This has to be done in the Symbol Editor.
    E.g. a reset-pin of an IC (D1.5) could look like this D1.RESET
    Jos van Gemert
    Philips Medical Systems Netherlands
    Originally posted in cdnusers.org by jvgemert
    JB71,
    There are some packages (like the overly priced garage-shop Altium Designer that I am now forced to use) that allow one to assign net names to pins of a library footprint.  It's a useless and possibly dangerous feature.  I believe net names should only be associated with the pin of a footprint after it is brought into the PCB.  Though APD may be another matter.  One nice thing about ADD is the pin number and/or net name has always been only viewable if the appropriate top or bottom layer is selected.
    Cheers!
    Drew
    Originally posted in cdnusers.org by drew3rdof3
