  3. Setting accuracy to 0 results in no shape spacing
  • Views 12425
archive over 19 years ago
Hello all,
I have set the accuracy to 0mil [0 decimal places] in Setup > Drawing Size. Once I click OK, the spacing between shapes and everything drops to zero even though I have 8mil in all blanks under the Global Dynamic Shape Parameter menu Clearance tab.
I have thought of 3 possibilities: Is there a setting somewhere else that I've missed? Could the clearances go to 0 because of a math rounding error? Maybe it's just a bug?
Thanks in advance.
Originally posted in cdnusers.org by Evan Shultz
    The problem was that Dynamic Fill was set to Disabled. Changing this setting to Smooth fixed everything. The Dynamic Fill settings are accessable from Shape > Global Dynamic Params under the Shape Fill tab.
