  3. Detecting Allegro database version
  • Subscribers 163
  • Views 14634
archive over 19 years ago
Is there a UNIX command that will return the tool version in which an Allegro database was created?  We have databases in both 15.5 and 15.5.1, and need to distinguish between the two of them in order to setup the correct environment in some automation scripts.  This is important because a design created in 15.5.1 cannot be opened in 15.5.
Thank you,
- Phil
Originally posted in cdnusers.org by phil_alberg
    I used the "dbstat" command to identify the tool version of an Allegro database. (dbstat <*.brd>).
    It does not matter if you saved the Allegro database at a higher dot version unless you use functionality on that version it will remain at the lower dot version. In other words, if you uprev an 14.2 Allegro database to 15.5.1 it will be marked as a 15.2 database until you make changes which are only supported on the higher dot versions. The same holds true when creating a new design using File > New where dbstat will report that the database is 15.0.
    One final note, when running the dbstat command on an Allegro 15.5.1 database it will report the version as 15.6 at least on the designs I have been working on.
    Hope this helps,
    Mike
    Originally posted in cdnusers.org by mcatramb91
