  3. Import 2 *.brd files -- merge boards : allegro PCB edit...
  • Subscribers 162
  • Views 3542
Import 2 *.brd files -- merge boards : allegro PCB editor
archive over 20 years ago
I can't import or merge 2 .brd files.
I looked up hierarchy and merge, but didn't find much.
Allegro PCB editor 15.2
Thanks.
Kevin.
Originally posted in cdnusers.org by kevinj
    Hi Kevin,
    You can but it is not straight forward. You need to merge the two databases by importing one of the .brd files into the other. This could be done in different ways but the bottom line is that you need the logic for both designs to be incorporated as one. If you are using a 3rd party netlist then this is not an issue as you can readily merge netlists and if you are using a circuit driven design then the circuits will also need merged. If your databases are logic driven then you could create a hierarchy including the two boards and you could possibly use re-use modules to create the combined databases.
    If you are using 3rd party netlists then you can recreate one of the databases within the other by outputting the data and reading this into the other. Much the same as you would re-create a corrupted database. Be aware though that your reference designators will need to be different between the two databases. An auto-rename would resolve this prior to outputting the clips and logic. See sourcelink article.
    http://sourcelink.cadence.com/docs/db/kdb/1998/Sept/1816549.html
    Cheers,
    KP
    Originally posted in cdnusers.org by kp
    The link you posted is for an error message "descendent of .sav, not reliable call Cadence Support."
    Problem :
    Allegro v13.x rebuilding a corrupt (.sav) database using clipboard.
    Is that the link you intended to post?
    I think my problem is different. Thanks. Kevin.
    That was the correct link, the same principle applies. Instead of reading the generated files from one of your databases into a new .brd file you read the files into the other database. This creates one database which contains the contents of both databases. N.B. There must not be duplicate reference designators and you must offset the datums so that the designs are not placed direcly on top of each other.
