  3. export to IDF
  • Subscribers 162
  • Views 15314
export to IDF
archive over 20 years ago
Hi, guru!
I can't export properties (RESISTANCE, THETA_JB, etc.) from Allegro (15.5) to IDF (v.3) library file.
Tell me what I need to do.
Thanks.
Originally posted in cdnusers.org by malex
    These properties must be attached to the component definition to be exported to the IDF Library file.
    Originally posted in cdnusers.org by johnsc@cadence.com
    After attachment IDF properties to the component definition (trough device file) the idf_out command is failed. What I need to do next?
    Thanks.
    Make sure that IDF verion 3.0 is specified. If you are using the idf_out batch program the default version is 2.0. You need to specify -V 3.0 .
    If 3.0 is selected and you're still not getting the properties, you should contact Cadence support.
