  3. Rule AREA
  • Views 13278
Rule AREA
archive over 19 years ago
Hi All
Is there a way to define differnet line width and spacing for a specific area in the PCB ?.
if yes : do i define it in Allegro ( or can it be defined some how in Orcad Capture ?) is it being passed to the auto router ( specctra ), are there any other properties specific to an area ?
thank's
roby
Originally posted in cdnusers.org by robyd
    You can define an area in Allegro, these come in two forms, Physical and Spacing. Within an area you can specify any linewidth or spacing, via choice basically any physical or spacing attribute may be changed to refer specifically to your area. Remember the ruleset that you create and apply must be defined and attributed in the Constraints / Assignment table.
    Originally posted in cdnusers.org by kp
    Hi kp
    can these rules be different for few net classesor nets in the same area ?
    roby
    Roby,
    The simple answer is yes.
    Create and attach the same physical property to the required nets as well as the area and, as KP implied, set up the assignment table so those nets obey the rule only in that area.
    Cheers!
    Drew
    Originally posted in cdnusers.org by drew3rdof3
