  3. Attach signal name to part in Capture and display in Al...
  • Subscribers 163
  • Views 14223
Attach signal name to part in Capture and display in Allegro
archive over 19 years ago
How to add text (net name) to a part in Capture and show it as silkscreen in Allegro?
I tried to create a new property to a part in Capture, e.g. PART_TEXT and add one line under [ComponentInstanceProps] in allegro.cfg file, PART_TEXT=YES. But this property can't transfer to Allegro.
What is the right way should I do?
Originally posted in cdnusers.org by Azure
    Does the property get included into the Allegro netlist file?
    Try setting up the property PART_TEXT in the Allegro .brd and then re-transfer the netlist into Allegro - here are the steps:
    1) in Allegro go to Setup > Property Definitions
    2) Enter PART_TEXT in Name edit box
    3) Click on Apply
    4) Select appropriate 'element' and data type (string should work)
    5) Save the .brd
    6) Import the netlist
    Originally posted in cdnusers.org by khurana
