  3. REUSE MODULE
  • Subscribers 163
  • Views 13744
REUSE MODULE
archive over 19 years ago
Hi forum!
I have use a module in my design. The module is getting into the design OK. But I am having a problem with big diamond shapes are appeared on the design every time I move or reroute the traces. There are nothing to indicate what kind of the problems that is. Have any body in the forum seen this? Please, help. Thank you and have a great day.
DDT
Originally posted in cdnusers.org by Daniel_Alcon
Diamond.doc
    I've seen this where the cline on one side of the diamond has the "FIXED" property and the cline on the other side doesn't. The diamond is showing you that what appears to be a single cline is actual multiple clines.
    Originally posted in cdnusers.org by Randy R.
    This diamond mark is referred to as a "connect point" or "cpoint". The displayed size of this connect point is controlled by the "Connect point size" field in the Drawing Options >Display Tab
    There is no "influence" of the design other than marking where a FIXED cline segment joins a cline segment that does not have the FIXED property. This is a feature of the fixed segment which lets the user know where clines join that have differing FIXED property values.
    To remove them you must first remove the fixed property from nets and clines. Then you want to simply pick up all the etch on all layers and then place it down in the same x,y location. This is done using edit-move with the find filter set to clines and vias. Select all the etch by window. Use 0,0 as the pick origin and then use 0,0 as the destination.
    This procedure may still not work. If there are "groups" in the design, you will have to remove these also before performing the above procedure. Once the diamonds are gone you will be able to slide the etch as a single cline segment.
    regards
    Originally posted in cdnusers.org by andrewjw
