  3. allegro export ICX error!!!! help!!!
  • Views 12676
archive over 19 years ago
  i follow the mentor ICX 3.0 user manual step to setup the interface to allegro ,
  when i export the *.brd file in allegro 15.5 PCB design 620 to ICX ,the system report as below :
   " Version: 2.4   Date: Mon Aug 01 14:00:00 PDT 2000
     using pxa270.ndd as output filename
     Loading axlcore.cxt
     E- *Error* fprintf/sprintf: format spec. incompatible with data - nil
   can you tell me how can i do to fix the error ! thanks
   or tell   me the step you setup the allegro interface to iCX !!
   thanks a lot!!
Originally posted in cdnusers.org by upton_zhou
    Your problem is due to Allegro 15.5 database. ICX import script currrently only works up to Allegro 15.2 (I had the same problem a few months ago when I updated to 15.5, and then went back to 15.2 because of needing to have interoperability with Mentor tools).
    Jeff
    Originally posted in cdnusers.org by Jeff_Johnson
