  3. total copper on the board
  • Views 13807
archive over 19 years ago
Hi experts,
Is there any way to extract total amount of copper present in the design?
In all layers, all database elements.
thanks,
Saad.
Originally posted in cdnusers.org by Saad
    Hi Saad
    You could use the film area command - type film area on the command line. This relies on all the artwork layers being setup and will then generate a report for the films defined and how much area used by the elements on the layers.
    Andy
    Originally posted in cdnusers.org by andrewjw
    You can generate the Film Area Report after you setup the Artwork Film Records.
    This report will calculate the Area in Sq inches for each film record defined.
    Just type "film area" on the Allegro command line or select the Film Area Report under Tools > Reports.
    The Allegro command line allows you to select certain film records to report using the -f option:
    syntax: film area [-f ] [output file name]
    example: film area -f top my_film_area_report.txt
    FYI: This report will take a little time to run depending on the amount of data on each of the film records.
    Mike Catrambone
    UTStarcom, Inc.
    Originally posted in cdnusers.org by mcatramb91
    Thanks Andy, thanks Mike.
