  3. Slide Problem
  • Subscribers 163
  • Views 15675
Slide Problem
archive over 19 years ago
As of yesterday I have a new quirk with Cadence Allegro 15.5 s050. Everytime I slide a trace or a via, the trace attached to the net changes width and goes to the default minimum trace width. I can only think that I have set a switch somewhere telling Allegro that this is what I want, however I most certainly do not. If anybody has any advice I would sure appreciate some relief from the major time waster! Thanks, Tom
Originally posted in cdnusers.org by Milhaus
    Am I the only one seeing this problem? At this point the Slide command has become totally useless.
    Check if you have the min and max line widths set properly . If the line is wider and getting thinner when you slide then check that the max width is set t othe max width the lone can be or 0.
    If the line is getting wider when you slode check the min neck with and length settings.
    Gerry
    Originally posted in cdnusers.org by gerrym_fcs
    I kind of remember this once before but I can no longer replicate it. It may of been addressed on a later ISR. I have tried to replicate this on SPB 15.5 and SPB 15.5.1 with no luck.
    To narrow down what the problem is I would suggest testing slide on multiple designs or a brand new database to see if it still acts the same way.. At least that will tell you whether it is Release/ISR related or design setup related.
    Mike
    Originally posted in cdnusers.org by mcatramb91
