  3. Best way to route a high amperage trace
  • Subscribers 162
  • Views 15672
archive over 19 years ago
I have a 2.2 amp signal that needs to enter a backplane connector, but due to pin spacing and pad dimensions, I am unable to route a 60 mil trace.
(pins are at 100 mil spacing with 40 mil pads, which leaves max trace thickness of 20 mil in between pins)
Should I neck the trace down, or should I break the trace down to two samller traces entering the pad.
Any help would be appreciated.
Originally posted in cdnusers.org by abelsh
    I appreciate the replies, Great suggestions.
    Mike, one of the problems with running a copper pour is that I have multiple 2.2 a signals on adjacent pin pairs. Plus I have to run them as diff pairs. Its a signal and its return path.
    So it looks like multiple traces it is. Should these be run on different layers ? Same Layer? Can I run one single 60 mil trace and then break it down to three individual 30 mil traces only where I need to?
    Thanks for all your time and helping me learn.
