  3. How to delete a Void~
  • Subscribers 162
  • Views 20932
archive over 19 years ago
How to delete a Void, which created by deleting islands?
When you run the command Delete Islands, there may be many Soids created in a Shape.
You can slecct the Void's boundary and edit it, but you can't delete it.
When you need re-edit the shape, It's difficult to remove these Voids.
Does anyone have a good solution?
Originally posted in cdnusers.org by leonlee
    My solution would be a SKILL routine that would, for a selected shape:
    1) copy pertinent info about the shape (layer, vertices, voids, etc)
    2) delete existing shape
    3) create new shape based on 1) but withOUT including any void info, thus giving you a shape just like the original but without the voids.
    HTH,
    Chris Walters
    local Cadence guru
    (Apple)
    Originally posted in cdnusers.org by kerchunk
    Posted By kerchunk on 7/17/2006 3:07 PM
    HTH,
    Chris Walters
    local Cadence guru
    (Apple)
    Actually, it's easier than that. If you query the voids created by the "Delete Islands" command, you'll see they all have a property attached to them. I use SKILL to delete the voids that have this property.
    Doug Stanley
    Originally posted in cdnusers.org by dgstan
    If I have created a bunch of voids by deleting islands and then want to go back and get rid of the voids, I will got to Shape>Manual Void>Delete and then select the shape I am working with and then right click and select Delete All. As an alternative, you can follow this procedure and delete the voids one at at time.
    Originally posted in cdnusers.org by Milhaus
