  3. putting a plcc120 at 45 deg rotation how to?
  • Views 12952
archive over 18 years ago
As the subject says can anyone tell me how to rotate or build an IC so it goes on the board at a 45 ? Using Allegro 15.7 performance.
TNX!
Joe
Originally posted in cdnusers.org by weissj3
    Make the symbol up as normal i.e. orthogonally
    When placing your symbols on the ‘Ministatus Form’ -> ‘Options’ tab set your angle to be Incremental – 45. Right Click -> Rotate and it will rotate at 45 degrees.
    KP
    Originally posted in cdnusers.org by kp
    THANKS! That worked.
    Knew there must be somthing I was missing, just didn't look at options DOH
    Rgds
    Joe
