  3. Controlling the Device Type value when I running Export...
  • Subscribers 163
  • Views 13457
Controlling the Device Type value when I running Export Physical
archive over 19 years ago
ConceptHDL 15.5.1, Front to Back Flow, question.
I would like to control the Device Type value during Packaging such that I can specify
an explicit value. Currently, the Device Name value formed by Packager-XL appears
to be formed by the concatenation of the PART_NAME, Key Properties and Injected Properties.
The resulting Device Type value is very long and contains illegal characters that will
break downstream tools.  I thought I addressed this issue by specifying an explicit
value for the Row Name inside of the Part Table (PTF) but all it did was add it as
a suffix followed by Key and Injected Properties.
Has anyone ran into this before and found a workaround.
In the PTF File a specify the Row Name (~explicit row name)
: PART_NUMBER    | JEDEC_TYPE                               =
'IXX0005606'       | 'TSOP56_0196_01C' (~IXX0005606) =
(Note this is a partial PTF file - Injected properties omitted for clarity.)
Device Type value using Show Element in Allegro:
Resulting value
Device Type:   IXX0005606-TSOP56_0196_01C,VCCA
Expected value
We just migrated over to ConceptHDL for DxDesigner (EPD)
and most of our programs key off of the Device Type value
which was previously driven by the Device file names.
I have a case open with Cadence but I figured I would
bounce it off all of you just in case you have dealt with
this in the past.
Thanks is advance,
Michael Catrambone
UTStarcom, Inc.
Originally posted in cdnusers.org by mcatramb91
