  3. Skill script cwidth.il - not working?
  • Subscribers 163
  • Views 718
archive over 19 years ago
I have a skill script called cwidth.il  I haven't used it  for a while . Now I need to use it desperately and it does not work. I have trived both V15.2 and V15.5. The error is as follows:
Loading signal.cxt
Loading axlcore.cxt
** Selected 218 Cline Segments. **
** Changing 218 Seg Widths, please wait.
E- *Error* setq/set: Variable is protected and cannot be assigned to - newline
Command >
It did not change a thing.  One thing it DID do was turn off all subclasses except the etch subclass I was changing.
does anyone have a working version of this script or a script that changes the cline width on a layer and segment basis?
I've attached my version of the script.
Gerry
Originally posted in cdnusers.org by gerrym_fcs
cwidth.il
