  3. board outline segments merge
  • Views 16254
archive over 18 years ago
Hi everyone,
Have a great day ahead.
 I am using Allegro Expert 15.5.1. I am using up a complex board ouline, so i drew it in different segments. Now I am not able to merge these segments in class:board goemetry;subclass:board oulline for easing in my power plane cut. Can anyone suggest me a option to do so.
Thanking you in advance,
regards,
Pavan
Originally posted in cdnusers.org by pavan_m_33
    Hi Pavan,
    It should be possible to use the command Shape, Compose Shapes - have the "Use Autogap" checked in the options tab in the control panel. Now draw a box around the outline or alternately click each outline segment one at a time.
    Best regards,
    Ole
    Originally posted in cdnusers.org by ejlersen
    Hi Ole,
    Thanks for the solution, but after I run command, the outline dissapears, telling it cant complete the shape. Can u plz help me out??
    regards,
    Pavan.M
    first of all , make sure the class of original lines are substrate\outline(in apd) or "board geometry\outline(alg)"
    still the shape -> compose shape command
    autogap is optional ; make sure the active class are also the one(s) mentioned above
    make sure the lines are "closed", means they have no start point or end poitn, figureing a closed shape out
    take care and try it , hope this helps
    Originally posted in cdnusers.org by tfsummer
    If you want to merge lines, use Fillet command with a radius set to 0 (zero).
    Clic first segment, then second: they will be merged.
    Originally posted in cdnusers.org by jcteyssier
