  3. Orcad to PCB Editor error during Create Netlist
  • Replies 7
  • Views 19621
archive over 18 years ago
I obtain the following session log error when i tried to create netlist from Orcad Capture to be used by PCB Editor for layout. Kindly help. It seem to be due to naming conflict of component.
Is there a way to prevent the default naming component of Orcad to cascade during netlist creation?
many thanks
* Netlisting the design
Design Name:
Z:\Attogenix\Projects\Attocycler v2.0\Hardware\PCB\Cadence\Orcad\attocycler.dsn
Netlist Directory:
Z:\ATTOGENIX\PROJECTS\ATTOCYCLER V2.0\HARDWARE\PCB\CADENCE\ORCAD\allegro
Configuration File:
C:\OrCAD\OrCAD_15.7\tools\capture\allegro.cfg
Spawning... "C:\OrCAD\OrCAD_15.7\tools\capture\pstswp.exe" -pst -d "Z:\Attogenix\Projects\Attocycler v2.0\Hardware\PCB\Cadence\Orcad\attocycler.dsn" -n "Z:\ATTOGENIX\PROJECTS\ATTOCYCLER V2.0\HARDWARE\PCB\CADENCE\ORCAD\allegro" -c "C:\OrCAD\OrCAD_15.7\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
Scanning netlist files ...
Loading... Z:\ATTOGENIX\PROJECTS\ATTOCYCLER V2.0\HARDWARE\PCB\CADENCE\ORCAD\allegro/pstchip.dat
Loading... Z:\ATTOGENIX\PROJECTS\ATTOCYCLER V2.0\HARDWARE\PCB\CADENCE\ORCAD\allegro/pstxprt.dat
Loading... Z:\ATTOGENIX\PROJECTS\ATTOCYCLER V2.0\HARDWARE\PCB\CADENCE\ORCAD\allegro/pstxnet.dat
packaging the design view...
Exiting... "C:\OrCAD\OrCAD_15.7\tools\capture\pstswp.exe" -pst -d "Z:\Attogenix\Projects\Attocycler v2.0\Hardware\PCB\Cadence\Orcad\attocycler.dsn" -n "Z:\ATTOGENIX\PROJECTS\ATTOCYCLER V2.0\HARDWARE\PCB\CADENCE\ORCAD\allegro" -c "C:\OrCAD\OrCAD_15.7\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
*** Done ***
* Updating Allegro PCB Editor Board
Netlist Directory:
Input Allegro Board:
Z:\Attogenix\Projects\Attocycler v2.0\Hardware\PCB\Cadence\Orcad\allegro\attocycler.brd
Output Allegro Board:
Spawning... netrev.exe -5     -y 1 -n   -i "Z:\ATTOGENIX\PROJECTS\ATTOCYCLER V2.0\HARDWARE\PCB\CADENCE\ORCAD\allegro" "Z:\Attogenix\Projects\Attocycler v2.0\Hardware\PCB\Cadence\Orcad\allegro\attocycler.brd" "Z:\Attogenix\Projects\Attocycler v2.0\Hardware\PCB\Cadence\Orcad\allegro\attocycler.brd"
Reading File : Z:/ATTOGENIX/PROJECTS/ATTOCYCLER V2.0/HARDWARE/PCB/CADENCE/ORCAD/allegro/pstchip.dat
(00:00:00.01)
Reading File : Z:/ATTOGENIX/PROJECTS/ATTOCYCLER V2.0/HARDWARE/PCB/CADENCE/ORCAD/allegro/pstxprt.dat
(00:00:00.00)
Reading File : Z:/ATTOGENIX/PROJECTS/ATTOCYCLER V2.0/HARDWARE/PCB/CADENCE/ORCAD/allegro/pstxnet.dat
(00:00:00.01)
Starting to process component instances
netrev run on Nov 16 11:20:54 2006
   DESIGN NAME : 'ATTOCYCLER'
   PACKAGING ON May 28 2006 22:05:31
  8 errors detected
 No oversight detected
 No warning detected
cpu time      0:00:18
elapsed time  0:00:00
Exiting... netrev.exe -5     -y 1 -n   -i "Z:\ATTOGENIX\PROJECTS\ATTOCYCLER V2.0\HARDWARE\PCB\CADENCE\ORCAD\allegro" "Z:\Attogenix\Projects\Attocycler v2.0\Hardware\PCB\Cadence\Orcad\allegro\attocycler.brd" "Z:\Attogenix\Projects\Attocycler v2.0\Hardware\PCB\Cadence\Orcad\allegro\attocycler.brd"
Cadence Design Systems, Inc. netrev 15.7 Thu Nov 16 11:20:54 2006
(C) Copyright 2002 Cadence Design Systems, Inc.
------ Directives ------
RIPUP_ETCH FALSE;
RIPUP_SYMBOLS ALWAYS;
MISSING SYMBOL AS ERROR FALSE;
SCHEMATIC_DIRECTORY 'Z:\ATTOGENIX\PROJECTS\ATTOCYCLER V2.0\HARDWARE\PCB\CADENCE\ORCAD\allegro';
BOARD_DIRECTORY 'Z:/Attogenix/Projects/Attocycler v2.0/Hardware/PCB/Cadence/Orcad/allegro';
OLD_BOARD_NAME 'Z:/Attogenix/Projects/Attocycler v2.0/Hardware/PCB/Cadence/Orcad/allegro/attocycler.brd';
NEW_BOARD_NAME 'Z:/Attogenix/Projects/Attocycler v2.0/Hardware/PCB/Cadence/Orcad/allegro/attocycler.brd';
CmdLine: netrev.exe -5 -y 1 -n -i Z:\ATTOGENIX\PROJECTS\ATTOCYCLER V2.0\HARDWARE\PCB\CADENCE\ORCAD\allegro Z:\Attogenix\Projects\Attocycler v2.0\Hardware\PCB\Cadence\Orcad\allegro\attocycler.brd Z:\Attogenix\Projects\Attocycler v2.0\Hardware\PCB\Cadence\Orcad\allegro\attocycler.brd
------ Preparing to read pst files ------
Starting to read Z:/ATTOGENIX/PROJECTS/ATTOCYCLER V2.0/HARDWARE/PCB/CADENCE/ORCAD/allegro/pstchip.dat
   Finished reading Z:/ATTOGENIX/PROJECTS/ATTOCYCLER V2.0/HARDWARE/PCB/CADENCE/ORCAD/allegro/pstchip.dat (00:00:00.01)
Starting to read Z:/ATTOGENIX/PROJECTS/ATTOCYCLER V2.0/HARDWARE/PCB/CADENCE/ORCAD/allegro/pstxprt.dat
   Finished reading Z:/ATTOGENIX/PROJECTS/ATTOCYCLER V2.0/HARDWARE/PCB/CADENCE/ORCAD/allegro/pstxprt.dat (00:00:00.00)
Starting to read Z:/ATTOGENIX/PROJECTS/ATTOCYCLER V2.0/HARDWARE/PCB/CADENCE/ORCAD/allegro/pstxnet.dat
   Finished reading Z:/ATTOGENIX/PROJECTS/ATTOCYCLER V2.0/HARDWARE/PCB/CADENCE/ORCAD/allegro/pstxnet.dat (00:00:00.01)
------ Oversights/Warnings/Errors ------
#1   ERROR(302) Device library error detected.
Problems with device 'R_AX/RC05_15K'. JEDEC_TYPE property 'AX/RC05' is illegal: 'Package name has invalid characters or is too long.'.
Device 'R_AX/RC05_15K' has library errors. Unable to transfer to Allegro.
#2   ERROR(302) Device library error detected.
Problems with device 'R_AX/RC05_45K'. JEDEC_TYPE property 'AX/RC05' is illegal: 'Package name has invalid characters or is too long.'.
Device 'R_AX/RC05_45K' has library errors. Unable to transfer to Allegro.
#3   ERROR(302) Device library error detected.
Problems with device 'R_AX/RC05_22K'. JEDEC_TYPE property 'AX/RC05' is illegal: 'Package name has invalid characters or is too long.'.
Device 'R_AX/RC05_22K' has library errors. Unable to transfer to Allegro.
#4   ERROR(302) Device library error detected.
Problems with device 'R_AX/RC05_10K'. JEDEC_TYPE property 'AX/RC05' is illegal: 'Package name has invalid characters or is too long.'.
Device 'R_AX/RC05_10K' has library errors. Unable to transfer to Allegro.
#5   ERROR(302) Device library error detected.
Problems with device 'C_RAD/CK05_470N'. JEDEC_TYPE property 'RAD/CK05' is illegal: 'Package name has invalid characters or is too long.'.
Device 'C_RAD/CK05_470N' has library errors. Unable to transfer to Allegro.
#6   ERROR(302) Device library error detected.
Problems with device 'C_RAD/CK05_100N'. JEDEC_TYPE property 'RAD/CK05' is illegal: 'Package name has invalid characters or is too long.'.
Device 'C_RAD/CK05_100N' has library errors. Unable to transfer to Allegro.
#7   ERROR(302) Device library error detected.
Problems with device 'C_RAD/CK05_150N'. JEDEC_TYPE property 'RAD/CK05' is illegal: 'Package name has invalid characters or is too long.'.
Device 'C_RAD/CK05_150N' has library errors. Unable to transfer to Allegro.
------ Summary Statistics ------
#8   ERROR(102) Run stopped because errors were detected
   COMPILE 'logic'
   CHECK_PIN_NAMES OFF
   CROSS_REFERENCE OFF
   FEEDBACK OFF
   INCREMENTAL OFF
   INTERFACE_TYPE PHYSICAL
   MAX_ERRORS 500
   MERGE_MINIMUM 5
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
   NET_NAME_LENGTH 24
   OVERSIGHTS ON
   REPLACE_CHECK OFF
   SINGLE_NODE_NETS ON
   SPLIT_MINIMUM 0
   SUPPRESS   20
   WARNINGS ON
  8 errors detected
 No warning detected
cpu time      0:@Ú
00:18
*** Done ***
* Spawing Allegro PCB Editor
Spawing "C:\OrCAD\OrCAD_15.7\tools\pcb\bin\allegro.exe" -mpssession Administrator "Z:\Attogenix\Projects\Attocycler v2.0\Hardware\PCB\Cadence\Orcad\allegro\attocycler.brd"
*** Done ***
Originally posted in cdnusers.org by garylim
    Gary,
    I am not sure if the the character '/' is giving you error. May be you can replace the value in schematic with underscore '_' and give a try.
    Try setting the system environmental variable ALLEGRO_LONG_PACKAGE and value as TRUE, this will allow to read in the netlist with long package names into allegro.
    Just a quick guess :-)
    Good Luck!!
    Raj.
    Originally posted in cdnusers.org by rajpcb
    hi raj,
    Thanks for the fast response. Yes, we also suspect that was the issue. But it will be a integration nightmare to manual convert every component naming to fit Allegro requirement. Shouldn't cadence has design built in to rectify such integration problem?
    thanks for the ALLEGRO_LONG_PACKAGE tips.
    cheers
    gary
    garylim,
    i am so sorry to tell you that, maybe you have to modify the "pcb footprint" property of every component that caused error,
    some concept:
    property transition : Orcad Pcb footprint -> Allegro JEDEC
    there are no charactor available in "jedec" but english char like "a, b x..", numeric char like " 2 , 5 " and the underlin"_";
    and what's more, the design path of brds,symbles and pads do not permmit "space char" insede:)
    hope this helps
    Originally posted in cdnusers.org by tfsummer
    and a number , 18 , is the longest char length of legal symbole and pad name:)
    archive over 17 years ago
    I'm having a similair issue at the moment, I tried the underscore but it did not seem to work. I did this on a single part, I will try agian and see if this works. Its going to be a nightmare for me as well if I have to go and fix all the parts.
    Originally posted in cdnusers.org by Gun_metal
