  3. Allegro 2 PDF searchable text?
  • Subscribers 163
  • Views 13644
archive over 19 years ago
Hi all,
We are using Allegro v15.1 trying to plot pdf with searchable text in Adobe Acrobat standard 6.0?.
Can anyone help?
I saw the posting regarding mirrored text, but in v15.1, there is no "unvectorized selection" in plot set-up.
Only Vectorized, but is not searchable no matter if selected or not.
(see attached)
Mark
Originally posted in cdnusers.org by msalberg
    Mark,
    I know Cadence was bouncing back and worth with this. Originally there was a env variable to control whether the text was vecotorized or not which become obsolete by adding it to the Plot Setup form.
    I do not have access to V15.1 but in 15.5.1 under Plot Setup I see a General tab, which matches the original Plot Setup form, and a new Windows tab with a Non-vectorized text control section to specify font mapping during output. Is it possible you are pointing to an old form ?
    Hope this helps,
    Mike Catrambone
    UTStarcom, Inc.
    Originally posted in cdnusers.org by mcatramb91
