  3. Routing without nets
  • Subscribers 161
  • Views 14645
archive over 19 years ago
HI ALL,
Will doing the layout in allegro without schematic is possible. Is by anyway Routing can be done
without NETS and also without errors. how can it bring back to schematic.
Thanks & Regards
shiva.
Originally posted in cdnusers.org by pugal
    1. modify user preferences found in the "Setup" pulldown.
    - go to misc
    - add a check mark to ' logic_edit_enable'
    2. place parts on your board
    3. add connections
    - select the pull down menu "Logic"
    - pick "Net Logic"
    - create a netname under options in the control panel
    fyi
    I've only tested this with a netlist. Its woth a try.
    Good Luck,
    Oscar Miguelino
    Originally posted in cdnusers.org by oscar@oqo.com
    Oscar's method works for those preferring the 'blunt force' approach. It *always* ends up being better to start with the schematic and connecting to the board.
    Originally posted in cdnusers.org by redwire
