  3. No padstack specified!
  • Subscribers 166
  • Views 18713
archive over 18 years ago
when i try to ADD PIN command in symbol editing in ALLEGRO, in command line appears a "No padstack specified!" HOW to specify a PADSTACKS? (i point padstacks in constraints - don't care) help me please, tnx
Originally posted in cdnusers.org by chekunidze
    You need to specify the Padstack name under that Options tab on the right side control panel. See attached image. (Note: This only appears once you are in the Add Pin command)
    Also I would strongly suggest you review the Tutorials included with the Allegro PCB Editor documentation.  Quick access to them inside of Allegro using the Help Menu > Documentation.
    Mike Catrambone
    UTStarcom, Inc.
    Originally posted in cdnusers.org by mcatramb91
    Mike Catrambone
    UTStarcom, Inc.
