  3. Dynamic Shape & Artwork Error
  • Subscribers 161
  • Views 5862
archive over 19 years ago
Dear All
I am facing two problems in my design.
First one is about the dynamic shapes. If I am modifying the etches, dynamic shape is not changing accordingly to fill the blank area. I have to have use new shape & merge command to fill blank area with the shape.
The second one is about the artwork generation.
The warning messages while generating the atwork is
"photoplot window exceeds film size (x,y) stated in the parameter file"
"multiple 0 width lines: all will be treated the same as the first"
Please help me to solve these errors.
in advance thanx for support.
Originally posted in cdnusers.org by Rajiv
    hello Rajiv,
    For the first one:
    You need to delete all the voids on the shape. Voids will not be filled in with the shape though they are dynamice. You can select the shape and then go to shape->manual void->delete and then on the working window RMB->delete all voids.
    For the second one:
    Warning1:
    Try changing the Film size limits in the Artwork Control Form window (Manufacture->Artwork) on the General Paramters tab.
    Warning2:
    Try changing the undefined line width on the Artwork Control Form window (Manufacture->Artwork) from 0 to 10mils (or any other desired value).
    Originally posted in cdnusers.org by kishore
    Thanx so much dear....It worked ...
