  3. CREATING LAYER CROSS SECTION LEGEND
  • Subscribers 163
  • Views 13493
archive over 18 years ago
Hi. I am preparing manufacturing data for my PCB. Can any buddy help me to finding out that "How could we create the layer cross section legends and if i want to add some Note is there any automatic way to do this" Thanks M.SHAKIR
Originally posted in cdnusers.org by mshakir
    Cadence does not have an automatic x-section generation utility. There was a skill routine that was posted by Leon Lee on this forum that creates a good start for a drawing. Many users tend to use as many standard builds as possible and use already prepared Format symbols which are then loaded into the database.
    The same goes for the drawing notes where you can have a selection of text files in your library that contain your standard notes. These can be quickly placed with ‘ADD -> TEXT’. Choose your class, subclass and text size and left click where you want the text to be placed and then right click and select ‘Read from File’. If required the text can then be edited in the usual way.
    Originally posted in cdnusers.org by kp
