  3. how to run skill file
  • Replies 7
  • Subscribers 163
  • Views 24834
archive over 18 years ago
Hi All, i am trying to run skill file first time but when i type sikll on command line it shows error that "command not found" also i am getting same message when i am trying to "load a skill file. i am using allegro 15.7, can any buddy guide me how can i run the skill file on my system. thanks
Originally posted in cdnusers.org by mshakir
    The Skill interactive environment is not currently available in the lowest Allegro level (Studio).
    You need to load code using you allegro.ilinit file. Create a file by that name with your load statement in it.
    eg.
    load("drc_walk.il")
    axlCmdRegister("drc walk" 'drc_main)
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Another way is:
    1. Copy all the skill files that you have to a directory.
    2. Open the allegro.init file and load in all the skill files that you copied to your directory.
    An example of the allegro.init files looks like this:
    setSkillPath(buildString(append1(getSkillPath() "D:/Projects/pcbenv/skill")))
    load("AAdd_AttachFile10E.il" "CopperCAD")
    load("add_device_label.il")
    load("add_symbol.il")
    load("addpinuse.il")
    load("align_sym.il")
    load("ASSEMBLY.IL")
    load("Auto_Balancing.il")
    load("autosilkUtils.il")
    load("build_ver.il")
    load("cds2f.il")
    load("cdw_axlLineXLine.il")
    load("cdwIsPointInsideCircle.il")
    load("check_short_segs.il")
    load("checkWidth.il")
    3. Finally you can close and open your allegro, if you have not closed it priror to following the above steps and play with your skill functions.
    Best Regards,
    Kishore
    Originally posted in cdnusers.org by kishore
    Hey Dave,
    Can you expand on the "Skill interactive environment " ? I heard about this many years ago but I did not think anything still exists.
    Mike Catrambone
    UTStarcom, Inc.
    Originally posted in cdnusers.org by mcatramb91
    Hi Mike, I'm not talking about the Development environment. (I think that is still available for a cost in Unix). Just the interactive environment - available by typing "set telskill" in the command window. Cheers, Dave
    type skill press enter key,
    load "skillfilename.il" press enter,
    type exit press enter,
    skillfilename press enter.
    Satya
    Originally posted in cdnusers.org by satya1234
