  3. How to change pick and place location for component
  • Views 13790
archive over 18 years ago
Hi, I made some connectors, when i tried to place those on the board it takes pin1 as a pick and place is there any way to change the pick and place to center. also if i want to change a via(no net) property to some other kind how could i do it without effecting the others vias of same kind Thanks
Originally posted in cdnusers.org by mshakir
    You may change your symbol origin to the geometric centroid of the part to achieve what you are asking.
    Keep in mind also, once you place your component that you have some flexibility in moving the part in Allegro. There are several options for selecting the origin in the control panel; Symbol Origin, Body Center, User Pick and Symbl Pin# (use any pin as the origin).
    Originally posted in cdnusers.org by annoonan
