  3. Should you have pads on the power and gnd layers in sta...
  • Subscribers 163
  • Views 14884
Should you have pads on the power and gnd layers in stackup
archive over 18 years ago
I am wondering if you need pads defined in the power and ground planes in my stackup.  I do have them defined in my routing layers, but are there any reasons to or not to have them for the power and ground planes.  Currently, I just have thermals and an antipad defined for them.
Originally posted in cdnusers.org by cadencesks
    Thanks Mike,
    that makes sense.
    What do you think about mounting holes? I was thinking that i would only need to use a pad on the top and bottom layers. I don't want to increase my capacitance or inductance by adding pads on the inner layers, but if I did that may add strength to the board. I also would not define thermal or anti pads.
    Louis
    Thanks Mike,
    that makes sense.
    Louis
