  3. Can Power Plane be used as a return
  • Views 13343
archive over 18 years ago
Hello All,
              I have a doubt , as we always try to use GND planes as the return path for our signal, can we use PWR plane as a return path for signals. If you agree with it do you have any paper or document which says that . It will be helpful.
Have a great Day
MAshak.M
Originally posted in cdnusers.org by mashak
    Planes, whether GND or PWR, definitely form a return path for the signals.
    Here is a good link that I can point you to help you understand more. Andrew Ingraham has good explanation:
    http://www.freelists.org/archives/si-list/08-2005/msg00253.html
    There are other good explanations as well on the same forum. Dig the mailing list to get more.
    Kishore
    Originally posted in cdnusers.org by kishore
