  3. Routing_with_fanout
  • Views 12265
Routing_with_fanout
archive over 18 years ago
Hi all,
I'm experiencing a problem about preserving
prerouted nets in  Allegro PCB editor.
In particular, in a first step I've successfully used  the fanout command
for a component.
Next I've started an automatical routing step which should complete
 the existing fanout connections.
I've tried to use the following properties
on fanout connections without  results:
-FIXED,NO_ROUTE: they prevents completing the connections
-NO_RIPUP:it reroutes the connections modifying the existing fanouts.
Could you suggest how to preserve prerouted fanouts
connections from successive autorouting steps?
Giohdl
Originally posted in cdnusers.org by giohdl
