  3. One point ground using dynamic shapes
  • Subscribers 163
  • Views 13556
archive over 18 years ago
Hi
I am using dynamic shpaes in my design. There are two different grounds & I want to make one point ground. How can it be done ??
Originally posted in cdnusers.org by Rajiv
    1) If they're on different layers and can be connected by pins or vias, add the NET_SHORT property to the connecting pins or vias.
    2) Add a zero-ohm resistor to the schematic connecting the two nets together.
    3) Create a fake part with an surface pin the size of the connection you want and use the NET_SHORT property.
    4) Use static shapes and waive the DRC.
    Originally posted in cdnusers.org by Randy R.
    A fake part can be created with an surface pin OR a internal pin.(net_short, of course)
    Work's fine also.
    The "little" problem with a fake part: it should have a place_bound so a drc appear if the "join" is done under a component: you will have to edit the fake's boundary or waive the drc
    Jean-Charles
    Originally posted in cdnusers.org by jcteyssier
