  3. ERROR(248)
  • Subscribers 161
  • Views 1598
ERROR(248)
archive over 19 years ago
Hello.
Can anyone please help me understand why the Packager gives me ERROR(248) :
"All physical pins are common in section 1 of physical part..."
When I check chips.prt,  all sections have at least one non-common pin. Why does this error persist? Is there something else that needs to be checked?
Thanks & best regards,
Estella
Originally posted in cdnusers.org by empsilva
    Hi Estella,
    Can you post just that section of the chips.prt file?
    I'll have a look.
    Thanks.
    Mitch
    Originally posted in cdnusers.org by cadpro2k
    Hi Mitch,
    Here it is:
    FILE_TYPE=LIBRARY_PARTS;
    primitive 'DPDT_TX2';
    pin
    'D':
    PIN_NUMBER='(5,0,5)';
    PINUSE='UNSPEC';
    NO_LOAD_CHECK='Both';
    NO_IO_CHECK='Both';
    ALLOW_CONNECT='TRUE';
    'B':
    PIN_NUMBER='(3,0,3)';
    PINUSE='UNSPEC';
    NO_IO_CHECK='Both';
    'C':
    PIN_NUMBER='(4,0,4)';
    PINUSE='UNSPEC';
    NO_IO_CHECK='Both';
    'I':
    PIN_NUMBER='(0,10,10)';
    PINUSE='UNSPEC';
    NO_IO_CHECK='Both';
    'G':
    PIN_NUMBER='(0,8,8)';
    PINUSE='UNSPEC';
    NO_IO_CHECK='Both';
    'H':
    PIN_NUMBER='(0,9,9)';
    PINUSE='UNSPEC';
    NO_IO_CHECK='Both';
    'J':
    PIN_NUMBER='(0,0,12)';
    PINUSE='UNSPEC';
    NO_IO_CHECK='Both';
    'A':
    PIN_NUMBER='(0,0,1)';
    PINUSE='UNSPEC';
    NO_IO_CHECK='Both';
    end_pin;
    body
    PART_NAME='DPDT';
    BODY_NAME='DPDT_MECH';
    JEDEC_TYPE='tx2';
    PHYS_DES_PREFIX='K';
    CLASS='IC';
    end_body;
    end_primitive;
    Thanks.
    Estella
