  3. How to get the padstack's informations?
  • Views 1754
archive over 18 years ago
How to get the padstack's information like as: Begin Layer, End layer, soldermask and pastemask, etc? with one command.
Is there any skill file to run the same?
How to measure air gap between solder mask pin to solder mask pin?
Thanks in advance,
SATYA
ATS ECAD
Originally posted in cdnusers.org by satya1234
    hello satys,
    regarding 1st query I dont think there is any option right now.
    But for second one you can activate measure command and in option tab select
    class - Pin
    Subclass - Solder mask *
    Originally posted in cdnusers.org by eswar
    Thank you,
    Any help for the first point?
    SATYA
    Regarding your first point: "How to get the padstack's information..."
    You can run the report command from a Dos Prompt or Unix Shell on the padstack file (.pad) with the following command: report -v pad .  This report does not require an special SKILL script because it is already part of the standard report tool.
    Here is an example:
    Command typed on the Dos Prompt: report -v pad pad30cir20d.pad pad30cir20d.rpt
    Below report is : pad30cir20d.rpt
    |                         PADSTACK  DEFINITION  REPORT                         |
    |        Page   1  |
    |  E:/pad30cir20d.pad                                                          |
    |  dimensions in mils                                Mon Jun 04 22:56:04 2007  |
    | Pad name: PAD30CIR20D              Type NON-VIA        Inner-pads OPTIONAL   |
    |    subclass or   | pad  |outline  |   size    |  offset   |  flash  |  shape |
    |mask-type or drill| type |geometry | wdt | hgt |  x  |  y  |  name   |  name  |
     TOP                PAD    CIRCLE       30    30     0     0
                        T-REL  CIRCLE       58    58     0     0
                        A-PAD  CIRCLE       58    58     0     0
     internal_pad_def   PAD    CIRCLE       25    25     0     0
                        T-REL  CIRCLE       53    53     0     0
                        A-PAD  CIRCLE       53    53     0     0
     BOTTOM             PAD    CIRCLE       30    30     0     0
     TOP-SOLDER-MASK    PAD    CIRCLE       50    50     0     0
     BOTTOM-SOLDER-MASK PAD                  0     0     0     0
     TOP-PASTE-MASK     PAD                  0     0     0     0
     BOTTOM-PASTE-MASK  PAD                  0     0     0     0
     TOP-FILM-MASK      PAD                  0     0     0     0
     BOTTOM-FILM-MASK   PAD                  0     0     0     0
    |    DRILL:        |
    |      hole     |  plating  |      display/plot        size      | hole offset |
    |      size     |   type    |   figure  |character| wdt  | hgt   |  x   |   y  |
          20         PLATED      CROSS                     20      20      0      0
    |   total padstack definitions 1                                               |
    Hope this helps,
    Mike Catrambone
    UTStarcom, Inc.
    Originally posted in cdnusers.org by mcatramb91
    Thank you..
    SATYA
    ATS ECAD TECH Pvt Ltd
