  3. How to make pin swap for component in capture CIS
  • Subscribers 163
  • Views 17785
archive over 18 years ago
Hi all
      I will be want know that How to make pin swap  for component in capture CIS.
and then how to release netlist?would angbody like help  me?
thanks a lot in advance.
cheers.
Planet.
Originally posted in cdnusers.org by Planet
    You must set up the pin properties in Capture first. Pin swap specifications will be produced only if the Swap Id properties are set correctly on pin-swappable parts.
    To do this, you can open the part in the library or select the part of interest in your design. Then, from the Edit menu, choose the Part option. From the View menu, choose Package, then from the Edit menu, choose Properties.
    In the Properties spreadsheet set the PinGroup value to 1 for each swappable (input) pin of the part. If you have a multi-section part you only have to set the PinGroup value for one section; the part editor adds the same value for all the other sections automatically. For example, on a 7400, set the PinGroup to 1 for pins 1 and 2. Leave the other PinGroup values blank and they are filled in automatically when you click the update all button. (PinGroup = 1 for pins 1, 2, 4, 5, 8, 9, 11, and 12.)
    When you select a pin and edit its properties, the value shows as the Swap Id property. The default value is –1, meaning the pin is not swappable. Therefore you must add the PinGroup property to enable pin swapping for your part if you want to be able to swap pins. Swap Id values greater than 0 in the property editor mean that the pin is swappable. If you made a pin swappable, and later decide to remove the swappability of the part, then you just delete the PinGroup property in the property editor. You can see which pins are swappable in the PSTCHIP.DAT file by looking for the PIN_GROUP line under the pin name.
    Generate the netlist as usually way.Import the netlist.
    In layout you can use place+swap+pins command .
    I hope it solves your problem
    SATYA
    AT&S Ecad Tech
    Originally posted in cdnusers.org by satya1234
    Hi Satya,
    problem is solved.
    Huge thanks!
    cheers.
    Planet
  • ghurley
    ghurley over 15 years ago
     An old post, but worth a reply...
     I am having problems getting the engineer to properly assign pinswap properties in Orcad CIS 16.3 so that I can do pinswaps in Allegro layout V16.3 and then back-annotate the changes.
    What IS the proper syntax for applying pinswap (swapID's) to symbol pins in CIS so that I don't get netlist/device file errors when netlisting into Allegro?
    Thanks!
    GregH
    Sr. PCB Designer contractor to multiple companies
